What to get? USB or adapter? [Wireless]
8 Oct 2010
I've been using this for YEARS:
Cisco-Linksys-WMP54GS-Wireless-G-Card-SpeedBooster
It's never failed on me once, despite it not being compatible with windows 7 and is really, really old, but I think the antenna is getting loose and isn't working as well as it should.
What's the main difference between USB and wireless card adapters?
What is better in general?
What's better gaming?
I've just bought the TP-Link TL-WDN4800 which uses the Atheros AR9380 chip. It's supposed to be good. However, I'll only get it installed when I move house in 10 days or so.
Ordered:
TP-Link 450Mbps Wireless N Dual Band PCI Express Adapter (TL-WDN4800) [TL-WDN4800]
(was out of order in ocuk, would have used otherwise)
Lets hope it works.
Good choice. You shouldn't run into any compatibility issues. Grab the latest drivers from the TP-Link website.
