What to get
16 Nov 2005
Torquay
Hi there,
Im currently lending some ram off a friend and he needs it back, the problem i have is trying to finding some ram that will run at the same speeds.
its at 255mhz 3,3,3,10 OCZ Gold 3700 i think*
I would need 2gb and my budget is arounds 170
Ps, my pc is overclocked using this ram at [email protected] '3700+ SD' so id prefer to keep this speed.
Sorry for a noob question, i dont have a clue about ram.
Thanks in advance
OCZ 2GB (2 x 1GB) PC4000 Dual Channel Gold GX XTC Series EL-DDR CAS3 (OCZ5002048ELGEGXT-K) (MY-060-OC)
- 500MHz DDR
- CL 3-4-3-8 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- Gold Layered XTC Heatspreader*
- Lifetime Warranty
- 2.75 Volts
- 184 Pin DIMM
- EVP®**
- ULN***
Price: £149.95 (£176.19 Including VAT at 17.5%)
these would get close.... 250mhz out of the box and at near enough the latencies you specify... cant imagine getting 5mhz out of them would be difficult.
Have same OCZ memory - can get 271 1:1 with it. It does'nt like a lot of volts but does like good air circulation.
