- 18 Oct 2012
hi guys, havent exactly posted on here much so go easy on me.
basically, about a year ago laptop died, and about 8 months ago went ahead and decided to have a crack at building me own pc, my lack of knowledge goes to show in a few areas, but one that seems to be bugging me the most of late is the case.
in case you don't know why this is bugging me, this is the case my 'infinite wisdom' had me buying:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-006-IW
before someone says it, no i'm not 14 and yes I do like how it looks [I have no sense of time, temperature and hearing so I imagine no sense of taste isn't a big leap from there]
basically, i'm considering changing it. the main issues i'm facing are thus:
internal space, or lack of, seriously the side fan is mounted outside because the graphics card wouldn't fit.
cables, so many cables, everywhere. I don't have OCD but every time I see the inside I feel like I do.
cooling, apart from the 200mm fan [which i approve of highly] there isn't any.
quality, the internals aren't painted. that is all
so, after that unnecessarily long back story, what good cases are there out there? i was looking at the likes of these:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-165-AN&groupid=2362&catid=2277
looks pretty good, plus it looks like it will take at least a 200mm rad [at the top?] and possibly a 360 at the front. don't have watercooling but its on the cards
http://www.overclockers.co.uk/showproduct.php?prodid=CA-237-CM&groupid=2362&catid=29
looks very good, less space for a 'standard' dimension rad, but i should assume a 200mm square rad wouldn't be too difficult to bolt in. plus if the large amount of 230mm fans [i approve of this] isn't enough then that 1.4m rear exhause fan should be good
for budget i don't really fancy going much further north than £100, those two look decent enough in terms of quality etc? anyone know of anything else that would happen to suit my tastes/budget, i don't really want anything too plain [ie just a black box] but i'm open to ideas.
