So I built the rig in my sig only 2 weeks ago. I like the look of the HAF 922, improvement over 932 I reckon. And it cools very well, especially as I have added the optional CM red led 200mm fan to the side. And the fans are all quiet as run off mobo and spin around 500rpm. My cpu cooler is also quiet...a couple of Akasa Apaches running in pwm mode, and my GPU's are quiet. The problem is, because of all the meshing..top of case, front of case, side of case, I can basically hear all the components. As quiet as they are, it's annoying. Should have got a case with less openings and I can't very well stick the HAF on the ground as I don't want to be cleaning it out very week.
With that in mind I am looking for a case which cools as well, but isn't as open. And it has to cool the gpu's well.
After reading lots of reviews, I can only come up with 3 cases which fit my requirement.
1. Antec P193....has sound deadening doors but also side fan for cooling gpu's. That side fan makes it look very ugly though and I don't like doors.
2. Coolermaster 840....can add 2 120mm fans to front HD cages to cool GPU's and hoping this case would match the HAF in cooling peformance. Side panels are very thin though. Worried about resonance. Reviews indicate it's geared as a negative airflow case so not as good as cooling gpu's as the HAF.
3. Silverstone Raven RV02...seems to be the quietest of the bunch with an innovative approach to cooling, and I guess I could loose one of my HD's as it will only take 3, plus as SSD around the side. And I'm sure I could fit the H50. Worried about cable management though, and while I know 5870's will just fit, I doubt the upcoming 5890 or Fermi will. So upgradabiliy could be an issue. Plus I hate side windows. And to top it all off, with only the H50 exhausting air in push/pull I wonder if this enough to get the hot air out of the case.
Any thoughts ?
Any thoughts ?
. Hmm...its the 193 or the 840. Leaning towards the P193 for now. Of course I could just buy one of those lian li pc stands and throw the case on it on the ground. Shouldn't pick up too much dust as new carpet just went down. Might be cheapest solution. I'm not after a silent case, just a case where I don't hear everything.
