What to upgrade next?
9 Dec 2006
@ManCave
I'm thinking, graphics but thought id hear your thoughts:
just for quietness and power consumption
i7 3770k @ 4.6ghz @ 1.143v
MSI Mpower Z77
Gigabtye 7990
16GB Patriot Intel Extreme 1600mhz
1x Samsung 830 SSD 128GB
1x Crucial M4 SSD 128GB
1x Samsung 840 SSD 128GB
1x 3TB Segate
USB DAC
Corsair HX850
750D case
140mm Noctua's Fan's
2713WM (2560x1080)
2x Dell 23" 1080p
Ducky Brown Mech keyboard
Razer Naga
AKG K702's
I agree that the gpu is going to be the noisiest thing there.
Also the 750D probably isn't the best case for airflow, not that I suggest changing it.
Obviously watercooling will make it quieter, but that is something I know absolutely zero about.
got 3 screens already :p, the case is good for airflow currently got 7990 at 75c max!
with no exhaust fans
dont like watercooling but thank you, also i got Air con in here so temps are good :) looks like gpu any ideas on upgrades?
In some ways yes, but in others no, 780ti is more efficient, cooler, uses less power etc. Having 2 though would be pretty good, what resolution do you play at?
Might be worth keeping the 7990 then, do you get low frames playing at high/max at all? If not i'm not sure to upgrade if anything.
