Hello.
I am getting some back pay this month (almost £400) and I could be sensible and save it or I could upgrade my PC. I am not sure what to do. Currently I have:
CPU: i5 6500 @ 3.2GHz
GPU: GTX 1060 6GB
RAM: 16GB DDR4 3200Mhz
MOBO: ASRock B150M Pro4s (this was a serious budget buy)
SSD: Samsung 850 EVO 250GB (plus some other random SSD with more space)
CASE: Fractal Define S
I play PoE and Destiny 2 a fair bit, usually solid 60fps (occasionally drops) in D2 on p high settings but PoE is putting serious stress on my system and getting mega frame drops. Other than that it runs fairly well but does drop frames here and there on bigger games e.g. Witcher 3 and what have you. Its 4 a years old PC.
My current line of thinking is that I could upgrade the CPU & mobo to Ryzen 3600 + some other mobo (not sure which, recommendations appreciated) and then upgrade my GPU to something fancier next year? Or is it not even worth doing an upgrade? I would like PoE to run better and I feel like the processor is the route to this.
Bottleneck calculator told me that upgrading to ryzen 3600 would result in 100% bottleneck from my GPU but I'm pretty sure that site is ********.
GPU: GTX 1060 6GB
