Hi
Back again,quick question,If I went out and brought a gtx590,would it work ok with my processor?
the card wouldn't bottle neck the processor, the processor will bottle neck the graphics card. you will need to overclock the the processor to 3ghz+.
what res are you playing at?
the 590 isn't worth it, better just get 2x 6950 2gb cheaper and faster.
Depends what resolution you game at mate....
Edit: beaten by fowler002.![]()
Would it work with your psu?
Well, I have a GTX260 which I run @ 1690x1050 (rig spec in sig) and tbh, thus far I don't feel the need to upgrade. COD Black Ops, F1 2010 etc etc etc all run superbly.
I'm going to see how BF3 runs on it then and only then will I seriously consider my upgrade, I'd advise you did the same tbh.![]()
