What to upgrade too?
29 Jul 2011
Near Northants / MK
Hi guys, just after a little bit of advice on the card situation.
Currently I'm running SLI 460's, I bought the 460 a few months back on the MM and whilst it gives a big performance boost, the heat, the power and the want in me to play BF4 means I'm looking for an upgrade.
Now the situation is, I don't really want to chuck more than £250 on a card, so what are my options, what would the 760Ti price fall into?
Most likely about £30 - £40 more than the 760. As I said ;)
And get a bigger CPU cooler and overclock that i5 you nonce. :p
If you don't mind AMD, nothing comes close to the high clocking 7950 Ice-Q(7970GE/680 performance) with 8 free games for £240!:eek:
Hi there
*****VALID FOR ORDERS PLACED BETWEEN 03/07/2013 - 31/07/2013*****
Exclusive to OcUK because we thought of it first and we have many many games, were doing an incredible Mega Bundle which ONLY comes with AMD cards listed in the OcUK Mega Bundle Section.
OcUK AMD Mega Bundle - GET Crysis 3, Farcry3, Farcry3 Blood Dragon, Tomb Raider, Simcity, Dirt Showdown, Sleeping Dogs & Bioshock FREE with Qualifying AMD Graphics Cards!! @ £149.99 inc VAT
The OcUK Mega Bundle comes with qualifying AMD Graphics cards, which are listed in this section. This bundle is only valid with orders placed between 03/07/2013 too 31/07/2013.
- Farcry3
- Farcry3 Blood Dragon
- Dirt Showdown
- Tomb Raider
- Simcity
- Bioshock Infinite
- Crysis 3
- Sleeping Dogs
- Only whilst stock last (subject to availability)
- For orders only placed 03/07/2013 - 31/07/2013
- Only with cards listed in the OcUK Mega Bundle Section, if the card is not within the OcUK Mega Bundle Section, it does not come with the OcUK Mega Bundle.
Only £149.99 inc VAT - YOU CANNOT BUY THIS IT IS FREE /w QUALIFYING AMD CARDS
ORDER NOW
The cards which qualify for this amazing deal are:-
Asus HD 7970 DirectCU II TOP 3072MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
The next generation Asus HD7970-3GD5 graphics card has arrived, fitted with a 28nm GPU that packs 4.3bn transistors and is combined with 3GB GDDR5 Memory, it provides users with the speed for smoother gaming. Supporting full DirectX 11, AMD CrossFireX and AMD HD3D, the GPU includes an exclusive tweak utility which allows users to tune the performance of up to four graphics cards and check card status via an intuitive interface.
This GPU Tweak function links the GPU clock frequency to the voltage, so as you scale the GPU clock the voltage automatically follows; a useful tool for inexperienced Overclockers, It also enables users to select between 2D and 3D mode by providing the ability to change the respective clock speeds, voltages and fan speeds of either. Disabling the 2D mode also forces the faster 3D mode, stabilising overclocking and benchmarking results.
Embedded with GPU-Z to access accurate graphics card information, the card also contains a live update driver and BIOS benefiting users with the ability to keep their card in the best condition. Widget monitoring provides the choice to display the most needed information including a full widget, light widget or real time monitoring.
Furthermore, new PCI Express 3.0 delivers improved encoding and twice the performance of the previous PCI Express 2.0 and vision horizons can be expanded across six displays with AMD Eyefinity technology. This technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
- Cranked 75MHz over reference for an ultimate engine clock of 1000MHz
- All new DirectCU thermal design utilizes six all-copper heatpipes and 20% bigger dissipation area, achieving 20% cooler and 14dB quieter performance than reference
- Acclaimed DIGI+ VRM with 12-phase Super Alloy Power technology delivers precise digital power and enhanced durability for stable overclocking
- VGA Hotwire allows you to plug and solder wires on the card’s voltage regulators and accurately read and control Vcore, Vmem, and PLL voltages on a hardware level
- GPU Tweak utility helps you modify and tune clock speeds, voltages, and fan performance via an intuitive interface
- One card drives up to six screens with AMD Eyefinity™ 6
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1000MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5600MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
Only £359.99 inc VAT.
ORDER NOW
Asus HD 7970 Matrix Platinum 3072MB GDDR5 PCI-Express Graphics Card @ £399.95 inc VAT
The ASUS ROG MATRIX HD 7970 continues the ROG tradition of catering to overclockers who want the fastest and smoothest performance. It meets extreme tuning needs, utilizing a TOP-selected GPU factory-set to 1100MHz. For hardware-level overvolting, customers get VGA Hotwire and the TweakIt interface, with one-press 100% fan speed settings. DIGI+ VRM digital controllers and Super Alloy Power components form the basis of massive 20-phase power delivery. Exclusive GPU Tweak has been enhanced for ROG duty, adding GPU loadline calibration and VRM tuning to an already full range of parameters.
DIY modification of voltages on MATRIX HD 797 becomes simple by removing the need for complicated and risky soldering. Just connect wires from dedicated headers on compatible ROG motherboards to VGA Hotwire connectors on MATRIX HD 7970, after which you can change voltages directly on the hardware level through the ASUS UEFI BIOS or via the Windows-based Ai Suite II.
TweakIt provides flexible overclocking control even when gaming or running benchmarks! The + and - buttons put overvolting adjustments at your fingertips, with more power translating into the faster and smoother gaming you crave and the winning edge you require for intense multiplayer and competitive benchmarking.
Instantly trigger the dual 100mm fans to 100% speed regardless of driver settings. This proves very useful in extreme overclocking and other heavy workload scenarios where rapid heat evacuation and max cooling are a must.
The Safe Mode button resets the graphics card back to default frequencies and BIOS settings. This is a very useful feature for hardware enthusiasts and experimental tuning - think of it like the motherboard's clear CMOS function.
MATRIX HD 7970 is built with carefully-designed massive 20-phase power delivery, unmatched by any other graphics card for the ultimate in performance and spectacular power delivery. This ensures ample room for experimental performance tuning, as its DIGI+ VRM digital voltage regulation design augments precision overclocking capabilities, which are further supported by the use of hardened Super Alloy Power capacitors, chokes, and MOSFETs. These components are forged under extreme pressure and temperatures to increase reliability, power output, and overall card lifespan while eliminating bothersome choke buzzing noise, unlike much tamer reference cards. All these and more enable the absolute best in overclocking potential and experience.
ASUS DirectCU thermal design utilizes all-copper heatpipes so heat is removed efficiently. DirectCU II generates 6X greater airflow yet performs 3X quieter than reference in idle and full load thanks to dual 100mm sound-dampening fans.
A color-coded LED MATRIX indicator at the back of the ROG MATRIX graphics card gives real time and easy-to-understand visual display of the current GPU workload, with colors changing dynamically depending your card’s work load.
Easily fine-tune core and memory clocks, voltages, and fan settings intuitively via sliders or manual value entry. MATRIX HD 7970 arrives with a new ROG edition of GPU Tweak, which adds detailed GPU loadline calibration and VRM frequency tuning, allowing for the most extensive control and adjustment parameters for maximum overclocking potential.
Features:-
- TOP-selected 1100MHz cores run 175MHz higher than reference for smoother gameplay.
- All new MATRIX thermal design utilizes six all-copper heatpipes and 20% bigger dissipation area, achieving 20% cooler and 14dB quieter performance than reference
- ROG GPU Tweak suite offers the world's first graphics overclocking tool with loadline calibration and VRM overclocking.
Specification:-
- Core Clock Speed: 1050MHz
- GPU Boost Speed: 1100MHz
- Memory Width / Speed: 384 bit / 6600MHz
- Power Connectors: 8-pin + 8-pin
- 20 Phase super alloy design
- Display Outputs: 2x DVI + 4x DP
- 3yr Warranty
Only £399.95 inc VAT.
ORDER NOW
HIS HD 7850 IceQ 2048MB GDDR5 PCI-Express Graphics Card (H785Q2G2M) @ £155.99 inc VAT
This HIS 7850 IceQ is a very special card and one which is exclusive to OcUK. Built using a 7870 PCB and the IceQ cooler from the 7870 this card has truly immense OC potential. Not only that but in its quiet mode the card operates in near silence. There is no better 7850 on the market and exclusively available from Overclockers UK.
With IceQ, the card is up to 20 °C cooler than the Reference Cooler. The super large 80 x 21.5mm single blower fan draws massive amount of cool air to cool the GPU directly. The fan is equipped with 2 ball bearing and is extremely durable with a life span of 50,000 hours! 4 wide heatpipes optimize cooling performance by removing heat from the core area. The extra large 35 x 30mm copper heatsink provides a large heat dissipation area. The card also features fan control and fan monitoring, you are able to read fan speed & Asic temperature from CCC or software. IceQ is one of the quietest coolers. The card is below 28dB dB when watching movies, surfing Facebook, working. The card is quiet in 2D mode and remains quiet whether you are gaming, online socializing, entertaining or working.
iTurbo is your software assistant to control your graphics card to be quiet, cool and experience overclocking by simply pressing the iTurbo Button! User Friendly Overclocking Software: Cooler, Quiter, OC!
iTurbo's Fan Control and Fan Monitoring allow easy adjustment of your card to its maximum cooling performance or to run your card quietly! Press iTurbo: OC Right Away! With the smart auto overclocking function, users can experience a slight performance boost for HIS selected graphic cards with just one click! Powerful Overclocking Software: Either you wish to unleash its full potential or to make it more environmental friendly, iTurbo is ready for you!
IceQ ensures effective cooling when there is another card in front blocking the fan inlet, such as in CrossFire setup. By expelling the hot air, IceQ removes all the heat generated by the GPU out of the computer chassis, prevents the hot air from accumulating inside and enhancing the overall stability. The more crowded the chassis, the greater will be the impact.
The demonstration shows that the IceQ does outperform the 3rd party cooler in closed environment. Cool air is drawn from both sides of the fan and hot air is forced out of the computer case. This ensures effective cooling when there is another card in front blocking the fan inlet, such as in CrossFire setup.
Black hole impeller ensures large amount of cool air is ready. It draws cool air from both sides of the fan even there is another card blocking the fan inlet on the front side of fan.
IceQ is one of the quietest coolers, making the card 8dB quieter than the reference cooler. The card is below 28dB when watching movies, surfing Facebook, working. The card remains quiet whether you are gaming, online socializing, entertaining or working.
Features:-
- Core Clock: 860MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Processing Cores: 1024
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Only £155.99 inc VAT.
ORDER NOW
HIS HD 7850 iPower IceQ Turbo 4096MB GDDR5 PCI-Express Graphics Card @ £209.99 inc VAT
Features:-
- Core Clock: 1000MHz
- Memory: 4096MB GDDR5
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £209.99 inc VAT.
ORDER NOW
HIS HD 7950 IceQ BOOST 3072MB GDDR5 PCI-Express Graphics Card (H795QC3G2M) @ £239.99 inc VAT
The World's first 28nm GPU. The revolutionary new GCN Architecture. Ready for DirectX 11.1. PCI Express 3.0. The AMD Radeon™ HD 7950 is your personal checklist for ground-breaking technology. The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better. Armed with the new PCI Express 3.0 standard, multi-GPU configurations with AMD CrossFire™ technology are just another way to obliterate the competition with the revolutionary AMD Radeon™ HD 7950. Leave no performance behind. Get higher clocks and faster gaming with AMD PowerTune technology on AMD Radeon™ HD 7950 Graphics. Fold and mine faster than ever with AMD App Acceleration powered by the unprecedented 28nm GCN Architecture. The market isn't ready for 4K video, but Radeon™ is. With full support for 3GHz HDMI 1.4a and DisplayPort 1.2 HBR2, the AMD Radeon™ HD 7950 is set for Quad HD.
This is the latest edition of AMD's Radeon 7950 GPU with Boost technology. What this means to the gamer is better FPS as the GPU automatically boost too 925MHz when underload to improve the gaming experience.
Features:-
- Core Clock: 850MHz (925MHz Boost)
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 2 Years
Only £239.99 inc VAT.
ORDER NOW
HIS HD 7950 IceQ X² BOOST 3072MB GDDR5 PCI-Express Graphics Card (H795QMC3G2M) @ £269.99 inc VAT
Hightech Information System (HIS) today announced the launch of HIS 7950 IceQ X² Boost 3GB. The card also has better OC capability and longer life span with HIS high quality component.
With IceQ X², the card is up to 17 °C cooler than the reference cooler. The super large 2x 8.9cm dual axial fans draws massive amount of cool air to cool the GPU directly. The fan is extremely durable with a life span of up to 50,000 hours. 3x 6mm and 2x 8mm wide heatpipes optimize cooling performance by removing heat from the core area. The extra large 40x47.5mm copper heatsink provides a large area to dissipate heat efficiently. The card also carries memory and mosfet heat sinks to provide extra heat dissipation from these areas. The card also features fan control and monitoring, you are able to read fan speed & Asic temperature from CCC or software.
IceQ X² is one of the quietest coolers. The card is below 28dB when watching movies, surfing Facebook, working. The card is quiet in 2D mode and remains quiet whether you are gaming, online socializing, entertaining or working. The card is up to 15dB quieter than the reference cooler.
iTurbo is your software assistant to control your graphics card to be quiet, cool and experiece overclocking by simply pressing the iTurbo Button! User Friendly Overclocking Software: Cooler, Quiter, OC! iTurbo's Fan Control and Fan Monitoring allow easy adjustment of your card to its maximum cooling performance or to run your card quietly!
With the smart auto overclocking function, users can experience a slight performance boost for selected HIS graphic cards with just one click!
Specification:-
- Core Clock Speed: 850MHz (950MHz Boost)
- Stream Processors: 32 CU / 1792 ALU
- Memory Width / Speed: 384 bit / 5000MHz
- 2yr Warranty
Only £269.99 inc VAT.
ORDER NOW
HIS HD 7970 IceQ X² 3072MB GDDR5 PCI-Express Graphics Card (H797QM3G2M) @ £329.99 inc VAT
Hightech Information System (HIS) today announced the launch of HIS 7970 IceQ X² 3GB. This world’s fastest card with single GPU is cooler and quieter with the innovative and performance-leading IceQ X² solution. The card also has better OC capability and longer life span with HIS high quality component.
Specification:-
- Core Clock Speed: 925MHz
- Memory Width / Speed: 384 bit / 5500MHz
- 2yr Warranty
Only £329.99 inc VAT.
ORDER NOW
MSI HD 7950 OC BE 3072MB GDDR5 PCI-Express Graphics Card (R7950-3GD5/OC BE G) @ £221.99 inc VAT
- Core Clock: 830MHz
- Boost Clock: 840MHz
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Only £221.99 inc VAT.
ORDER NOW
MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card **NEW REVISION** @ £249.95 inc VAT
nonl2br
<p><font size ="5"><b>Introduction</b></font></p>
<p>Leading global mainboard and graphics card maker MSI today announces the release of the R7950 Twin Frozr III/OC graphics card. This graphics card features the latest AMD 7950 chipset with 1792 stream processors and 3072MB of 384-bit GDDR5 high-speed graphics memory. The greatly improved overclocking potential and stability increases overclocking performance up to 37.5%! The highly acclaimed Twin Frozr III thermal design with 8cm Propeller Blades fan setup for 20% more air flow and 8mm SuperPipe technology is used for cooling. Fan noise of just 30dB at full load provides gamers the most silence user experience, while MSI Military Class II components are used to give the highest quality and stability. For gamers seeking overclocking potential, cooling and stability, the R7950 Twin Frozr III/OC graphics card offers the perfect solution! This Boost Edition has an impressive base clock of 880MHz, but even more impressive is the Boost clock of 960MHz out the box.</p>
<p>
<font size="5"><b>Key Features</b></font></p>
<table style="border-width: 0 0 0px 0px; border-spacing: 0; border-collapse: collapse; border-style: solid; border-color: #dcdcdc;" width="95%" border="0" cellspacing="0" align="center">
<tr valign="middle">
<td style="vertical-align: middle; padding: 4px; border-width: 0px 0px 0 0; border-style: solid; border-color: #dcdcdc;" width="150"><img src="http://marketing-uk.msi.com/images/MCII.jpg" width="150"></td>
<td style="vertical-align: middle; padding: 4px; border-width: 0px 0px 0 0; border-style: solid; border-color: #dcdcdc;" width="*">
<font color="blue" size="4"><b>Military Class II</b><br>
<font color="black" size="3"><b>Top Quality and Stability - </b>Components tested to US Military Standards Delivering Higher OC Capability, Better Power Efficiency, Longer Lifespan!</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 0 0px 0 0px; border-style: solid; border-color: #dcdcdc;" width="5px">&nbsp;</td>
<td style="vertical-align: middle; padding: 4px; border-width: 0px 0px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://marketing-uk.msi.com/images/Propellorblade.png" width="150"></td>
<font color="blue" size="4"><b>Propellor Blade Fan Technology</b><br>
<font color="black" size="3">MSI's exclusive fan blade design generates 20% more airflow covering wider area for the better heat dissipation.Only 30dB & 66Cunder full load!!!
</font></font></td>
</tr>
</table>
<p><font color="black" size="5"><b>Full Specifications</b></font><br>
<p><font color="blue"><b>Cooling: </b></font>MSI Twin Frozr III Dual Fan Heatpipe Cooler For Maximum Cooling Potential and Low Noise</p>
<p><font color="blue"><b>Memory: </b></font>3072MB GDDR5</p>
<p><font color="blue"><b>Memory Clock: </b></font>5000MHz (effective)</p>
<p><font color="blue"><b>Memory Interface: </b></font>384-Bit</p>
<p><font color="blue"><b>Shaders: </b></font>1792</p>
<p><font color="blue"><b>Bus Type: </b></font>PCI-Express 3.0</p>
<p><font color="blue"><b>Display Connectors: </b></font>2x Mini DisplayPort, HDMI, DVI-I</p>
<p><font color="blue"><b>Crossfire: </b></font>Up to 4 Way Support</p>
<p><font color="blue"><b>HDCP: </b></font>Yes</p>
<p><font color="blue"><b>DirectX 11: </b></font>Yes</p>
<p><font color="blue"><b>Open GL 4.2: </b></font>Yes</p>
<p><font color="blue"><b>Eyefinity: </b></font>Yes</p>
<p><font color="blue"><b>Powerplay: </b></font>Yes</p>
<p><font color="blue"><b>AVIVO HD: </b></font>Yes</p>
<p><font color="blue"><b>Warranty: </b></font>3 Years</p><br>
<br>
<br>
**Latest Revision with 100% fan problem fixed, now PWM fan control works and the end-user can also use manual fan control**<br>
Only £249.95 inc VAT.
ORDER NOW
MSI HD 7970 Lightning BOOSTED Edition 3072MB GDDR5 PCI-Express Graphics Card @ £399.95 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/ocuklightning.jpg" alt="Lightning" width="780" /><br>
<br>
<Font size="4"><b>Key Features</b></font><br>
<br>
<b>Unlocked Digital Power</b><br>
- Unlocked BIOS: One click to unlock all protections for extreme overclocking<br>
- Digital PWM Controller: More stable and precise voltage by digital signal<br>
- Enhanced Power Design: 2X Power output for maximum OC potential <br>
<br>
<b>GPU Reactor</b><br>
- An add-on device on the back of R7970 Lightning (Behind GPU) for the overclocking stability<br>
- Provide 88% higher power capacity and eliminate power noise (ripple)<br>
<br>
<b>Xtreme Thermal</b><br>
- Dust Removal technology on Twin Frozr IV keeps dust out for the best thermal condition<br>
- Dual Form-in-one Heatsinks provide better heat dissipation and strengthen the structure<br>
<br>
<b>Military Class III Components</b><br>
- Meet MIL-STD-810G standard to ensure the best stability and quality.<br>
- Adopt CopperMOS, Hi-c CAP, Golden SSC, and Dark Solid CAP<br>
<br>
<Font size="4"><b>Specifications</b></font><br>
<b>Graphics Engine</b> ATI Radeon HD 7970 <br>
<b>Interface</b> PCI Express x16 3.0 <br>
<b>Memory Type</b> GDDR5 <br>
<b>Memory Size(MB)</b> 3072 <br>
<b>Memory Interface</b> 384 bits <br>
<b>Core Clock Speed(MHz)</b> 1070 <br>
<b>Boost Clock Speed(MHz)</b> 1150 <br>
<b>Memory Clock Speed(MHz)</b> 6000 <br>
<b>DVI Output</b> 2
<b>Mini DisplayPort</b> 4 <br>
<b>HDCP Support</b> Y <br>
<b>HDMI Support</b> Y <br>
<b>Display Output (Max Resolution)</b> 2560x1600 <br>
<b>RAMDACs</b> 400 <br>
<b>DirectX Version Support</b> 11 <br>
<b>OpenGL Version Support</b> 4.2 <br>
<b>CrossFire Support</b> Y <br>
<b>Card Dimension(mm)</b> 305x135.5x40mm <br>
<b>Warranty</b> 3 Year<br>
ORDER NOW
Sapphire HD 7950 Boost 3072MB PCI-Express Graphics Card (11196-19-20G) @ £249.95 inc VAT
The SAPPHIRE HD 7950 3GB with Boost features SAPPHIRE’s new dual-extractor technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load.
SAHHPIRE HD 7950 3GB with Boost now has the latest GDDR5 memory clocked at 5000MHz effective, and runs with a core clock speed of 850 MHz which with PowerTune Dynamic Boost rises to 925 MHz on the engine.
For enthusiasts wishing to maximise performance, a new version of the SAPPHIRE overclocking tool, TriXX supporting this latest generation of technology is available free to download from the SAPPHIRE website. TriXX allows tuning of GPU voltage as well as core and memory clocks, whilst continuously displaying temperature. Manual control of fan speed is supported, as well as user created fan profiles and the ability to save up to four different performance settings.
Features:-
- Boost Clock: 925MHz
- Display Connectors: 1x Dual Link DVI, 1x Single Link DVI, 1x HDMI & 1x DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Sapphire HD 7950 Vapor-X OC 3072MB PCI-Express Graphics Card (11196-09-40G) @ £259.99 inc VAT
SAPPHIRE HD 7950 3GB OC with Boost Vapor-X Edition has the latest GDDR5 memory clocked at 5000MHz effective, and runs with a core clock speed of 850 MHz which with PowerTune Dynamic Boost rises to 950 MHz on the engine. It has a slightly less sophisticated 8-phase power design and the versatile output configuration of Dual-link DVI-I, DVI-D, HDMI and DisplayPort.
The Vapor-X cooler is based on a new vapor chamber designed especially for this series. Heat is carried away by four heatpipes (2 x 8mm plus 2 x 6mm), and finally dispersed by two 90mm fan with aerofoil blades and dust repelling bearings. The Vapor-X cooler easily handles the heat generated from the HD 7950 even under extreme load conditions.
Features:-
- Core Clock: 850MHz (950MHz in BOOST)
- HDCP Capable
- ATI Avivo HD
- Power Connectors: 2x 8-pin
- Warranty: 2 Years
Only £259.99 inc VAT.
ORDER NOW
Sapphire HD 7970 OC BOOST 3072MB GDDR5 PCI-Express Graphics Card @ £329.99 inc VAT
The SAPPHIRE HD 7970 OC Edition features SAPPHIRE’s new dual-extractor technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load. The HD 7970 from AMD is the most powerful single chip GPU ever built - it has a new internal structure with 32 compute units and a total of 2048 Stream processors. The SAPPHIRE HD 7970 OC Edition ships with a raised core clock speed of 950MHz, and 1425MHz for the memory. Its Dual BIOS switch allows users to select the higher performance settings of 1GHz core and 1450MHz memory, making the fastest card in its class. This setting also uses a more aggressive fan profile and raises the limits for maximum overclocking.
Features:-
- Core Clock Speed: 950MHz
- Boost Clock Speed: 1000MHz
- Memory Width / Speed: 384 bit / 5800MHz
- Display Outputs: 1x DVI-D, 1xDVI-I + 1x DP + 1x HDMI
- 2yr Warranty
ORDER NOW
Sapphire HD 7970 VAPOR-X GHZ 3072MB GDDR5 PCI-Express Graphics Card @ £341.99 inc VAT
The SAPPHIRE HD 7970 3GB Vapor-X Edition delivers a similar high performance as the HD 7970 6GB Vapor-X model but at a more aggressive price point. It has 3GB of the latest GDDR5 memory clocked at 6000MHz effective, and runs with a core clock speed of 1000 MHz which with PowerTune Dynamic Boost rises to 1050 MHz on the engine. It has a slightly less sophisticated 8-phase power design and the versatile output configuration of Dual-link DVI-I, DVI-D, HDMI and DisplayPort.
Vapor-X Cooling Design: The brand new Vapor-X cooling design is based on a new vapor-chamber designed especially for the HD 7970 Vapor-X. With two 90 mm HJB bearing fan and 2 x 8mm plus 2 x 6 mm highly efficient heatpipes, the cooler easily handles the heat generated from the HD 7970 Vapor-X even when it is running over 1000 MHz.
TriXX Utility: TriXX allows tuning of GPU voltage as well as core and memory clocks, whilst continuously displaying the temperature. Manual control of fan speed is supported, as well as user created fan profiles and the ability to save up to four different performance settings.
Features:-
- Core Clock Speed: 1000MHz (Boost 1050MHz)
- Memory Width / Speed: 384 bit / 6000MHz
- Display Outputs: 2xDVI + 1x DisplayPort + 1x HDMI
- 2yr Warranty
Only £341.99 inc VAT.
ORDER NOW
Sapphire HD 7990 6144MB GDDR5 PCI-Express Graphics Card @ £829.99 inc VAT
With more than twice the processing power of previous generation AMD discrete graphics cards, ATI Radeon HD 7900 Series graphics cards deliver a cinematic gaming experience and unprecedented performance.
Features:-
- HD 7990 is a dual GPU card
- Core Boost Speed: 1000MHz
- Stream Processors: 64 CU / 4096 ALU
- Texture Units: 256
- ROPS / Z-Stencil: 64 / 256
- Memory Width / Speed: 2x384 bit / 6000MHz
- Load / Idle Board Power: <500W / <3W
- Power Connectors: 2x 8-pin required
- Display Outputs: DL-DVI-I, 4x Mini-Displayport
- 2yr Warranty
Only £829.99 inc VAT.
ORDER NOW
That's a serious amount of good games with some very good cards, the value of those games is easily beyond £100 and some. :eek:
Posted from Overclockers.co.uk App for Android
I check the deals OCUK are offering on AMD cards right now. 8 free games.
I didnt think they were doing a ti? If they do it wont be till next year as they said the 760 was the last nvidia release this year
Ahhh damn, well I have to wait a month till I can even think about buying a graphics card.
