- 28 Jan 2006
my current specs
amd athlon64 3700+
asus A8N-sli se
2x 1gb ram
7800gt o/c to 460/1100
just after a bit of a boost untill the backend of this year without to much of an outlay, mainly for gaming
option 1
o/c my current CPU- would a better cooler/fan help?
get another 7800gt second hand and go sli
option 2
get an opteron 170
stay with a single graphics card
under load i'm getting GPU temps into the high 70's so i'm planning on getting a decent cooler. i looked at the zalman vf-900 but if i go sli i'll need 2 of them, are the cheaper coolers any good?
cheers
amd athlon64 3700+
asus A8N-sli se
2x 1gb ram
option 1
option 2
get an opteron 170
cheers
I am on water though and temps are really low so i can get away with it. I did see a big improvement in games as well. Shortly i shall be swapping my Sli'd 7800's for a single 8800, probably a GTX, but i will wait for the refresh which should be soon. Then when i am ready i can upgrade to C2D, but as thats basically new everything, that will not be for a while yet. A good single core is still pretty powerful.
