I mainly play bc2 everything high except shadows low and hbao off. Runs about average 40 fps maybe a little lower.
I had my eye on the Asus gtx 580
Btw my TV is 40".
750W - should be fine?
Yea 1080P
Its a Gigabyte modular psu![]()
http://www.overclockers.co.uk/showproduct.php?prodid=GX-248-AS&groupid=701&catid=56&subcat=1752
You could buy this and flash it to a 6970 and this card would be very capable .
I am thinking ahead in anticipation for BF3. Would the suggested cards be ample to play BF3 with all the eye candy on?
well if they aint then I would blame a crumy console port and sloppy coding.
I was waiting for some newb to suggest that, if the OP can afford a GTX580? then why not get the fastest single gpu card on the market.
I just recommended it so he could save himself a few quid because they aren't that much far away from each other performance wise and it uses less power and runs a tad bit cooler .
