Hi All
I was planning to build my own pc but I think I should be able to just upgrade the one I have now (only 8 months old).
The specs are:
I would like to buy a GT 560 and a new 2 TB hdd. I'm guessing my PSU isn't good enough for a 560, would a 650w psu handle everything fine?
I would like to put in 2 extra fans as I bought the pc pre-built, it has a stock cpu cooler on it so I was hoping for a little extra ventilation
To add extra fans, do they need to be connected to only the psu?
Thanks
The specs are:
Code:
Thermaltake V4 Black Edition Gaming Chassis
550W HEC Desktop Power Supply
Asus M4A89GTD PRO - USB3 and SATA 6GB/s Support - AMD 890GX, AM3, DDR3, ATX
Supports up to 12 USB 2.0 ports (8x mid-board, 4x back panel) + 2x USB 3.0 ports - M4A89GTD
AMD Phenom II X6 1055T Processor - (2.8-3.3GHz,6xTurbo Core,9MB Cache)
8GB 1333MHz Dual Channel DDR3 SDRAM - ( 4x2GB )
1GB NVIDIA Geforce GT430 with CUDA Graphics Accelerator - DX11
1TB Samsung F3 SATA 7200rpm 32MB Cache Hard Drive
22x SATA Dual Layer DVD-Rewritable Super Format ±R/±RW/RAM
7.1 High Definition onboard sound card - for 8 Channel Cinema sound
Microsoft® Windows® 7 Home Premium pre-installed
Free Microsoft® Office 2010 Starter Edition
Free Cyberlink Video Editing Suite - 7 titles (oem)
BullGuard Internet Security ver. 9 - 90 Day Trial - AntiVirus/Firewall/Backup/Spamfilter
2 x 1394a port(s) (1 at mid-board; 1 at back panel) - M4A89GTD PRO/USB3
Network Ready PCIe Gigabit LAN
To add extra fans, do they need to be connected to only the psu?Thanks
