What to use to stand case on.
10 Jun 2015
Hi all
Ive got my tower on my carpetted floor next to my desk as it has no room for the massive size of the tower. The tower has tiny feet, but also has an underneath fan.
Does anybody have any ideas of what i can use to sit the case on so one it has more space to retrieve air through the vent and two to stop it collecting so much dust from the carpet.
Ive looked online for caster feet but havent found anything decent and ive also seen those stands with the feet on where you can place a tower on and then move easier with the wheeled feet, they looked abit naff and i dont think my case would fit on one plus, the bottom of the stand would stop it from getting air :(.
Anybody got any ideas how i can higher the case of the ground??? Cheers all. ps not sure if this was the right area for the question.
Yup - Plank of wood... or door off a kitchen cupboard, if your case is wide. Probably best with some blocks nailed beneath it to raise it to your chosen height. I'd personally look to raise it at least 6".
The feet on the underside of the case should give it enough space through which to draw air.
Thereafter, you have hundreds of options, from purpose-built risers, to tea-trolleys, to just about anything you can afford!
