What Torch Should I Buy? - Fenix LD1 Review
18 Oct 2002
Sandwich, Kent
Ok, I've seen a number of threads on here asking 'spec me a torch'.
Well, here is a nice little review comparing a Fenix LD1 to a range of other commonly available torches. All torches are fully charged using fresh batteries.
Ok, the torches, from left to right
1. 28 LED ebay torch. 3 x aaa.
2. Fenix LD1. 1 x aa.
3. MDXL 5w Luxeon. 3 x aaa.
4. Hugsy G2 7w Cree. 2 x CR123a.
5. Mini Maglight. 2 x aa.
Ok and now onto the beams. All images taken with the same settings.
Important things to add to this is that whilst #4 looks very bright, after only 5 minutes it is almost flat. This may be mostly to do with the difficulty in finding decent CR123a rechargeable batteries. However this is a real problem, when you compare it to the ease in finding decent, high power AA rechargeables.
Also, let this be a lesson to anyone daring to recommend a terrible, useless maglight. :p
Edit - Forgot to add. 5 and 6 are both the maglight, but with different beam settings.
Yep the only thing is though if you use a maglite with a conversion kit or one of the new mini led maglites the battery life will far outstrip the other torches.
I've got the MDXL jobbie, but when i had a look the LED was a knock off, not a real Luxeon :(
I love my maglite and my dynamo torch, but I quite fancy one of those Hugsbys. Where can I buy such a wondrous photon channeling device? eBay is heaving with what appears to be chinese knockoffs. Is that what they are?
I think Bug One should sit and watch the torches for the next 2-8 hours and tell us the battery run times. Then do the whole test again with rechargables so we can see the difference the lower voltage source gives.
:D
I got an L1D last year and still on the same battery that was supplied with it, even after a weekend at Reading Festival and numerous trips and things since, it's been great :)
No, I mean how long will it last per charge?
It comes with a non rechargeable. So I think he's trying to say it lasts quite a while. Plus its digitally controlled, so should maintain brightness regardless of charge.
On turbo mode, they state that it will last an hour and a half. On moderate power mode it will last much much longer.
I dont know how you can compare this with a D cell maglite. Its probably 10 times bigger and 20 times as heavy. The fact that this is still probably putting out more light is pretty astounding.
Dont do it! Its an awsome torch, for 5 minutes. Then it goes flat. Unless you want to shell out a fortune for lithium CR123's.
If you want photonic power, get the fenix. If you want even more power, get the 2 x aa version which lasts longer, puts out more light. But obviously is a bit bigger.
Ok, thanks. Been looking at that thread where the guy that ran fenixtorch.co.uk posted. Some tempting lights on there.
