They are quite exensive as well!! I would suggest somthing like the Xigmatek fans, around £8 each and theyre very good and very popular. And theres Yate Loons for around £5, another popular choice
If I was you I'd go for some cheaper fans and then get somthing like a DDC Pro with res top. A much better pump to be honest. Or get it with a normal top if you really want a bay res. Its not as powerful as the Ultra, but its quite a bit quieter, quite a bit cheaper and should be fine for the loop you've listed
