What TV tuner?
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi.
Thinking of spending around 30-40 quid on a TV Tuner, any good ones around that price? Ones that can record different channels whilst watching another and also have freeview?
Anyone? :(
Looking at these:
http://www.overclockers.co.uk/showp...=Leadtek Winfast DTV2000H Hybrid PCI TV Tuner
http://www.overclockers.co.uk/showp...ate DVB-T220 Digital TV Internal PCI - Retail
http://www.overclockers.co.uk/showp...ick with Windows Media Centre Remote - Retail
Dunno which one is the best or if any of the others in the price range are better.
Do they all do recording at the same time as been able to watch another channel and do they all have like interactive support, you know the red button thing.
Anyone? :(
Looking at these:
none of them above are dual dvb-t. which means they only record what u are watching.
u need something like this http://www.overclockers.co.uk/showp...l DVB-T Hybrid Internal PCI TV Tuner - Retail
as for interactive support no dvb-t cards have software for that. u will need windows media center tv pack 2008 update for vista to get that feature.. but the update is only for oem vista systems.
im running the pack, it as some nice features..
Windows Media Center TV Pack 2008
Code Name: Fiji
The Windows Media Center TV Pack 2008 is an upgrade to Media Center functionality released in Vista Home Premium and Ultimate. However, there are some important notes and installation instructions you should be aware of before attempting to install the package.
Important Notes:
-The Media Center TV Pack is only being released externally via licensed OEMs. Therefore, installation of the TV Pack must be on top of a clean Vista SP1 install. There is no upgrade from Vista RTM or previous versions of Windows XP Media Center Edition.
Is that one you linked to really worth the money?
Also do I just do a fresh install of Vista then slap that TV pack in? Bit annoying I took Media center out of this installation :(, is it possible to re install it?
Installation Instructions:
1. Prepare a machine with clean install of Vista SP1.
a. The machine will need to meet or exceed the minimum hardware requirements for Vista​
b. The Vista SP1 OS must be Home Premium or Ultimate (x86 or x64)​
c. Following OS install, do not launch Media Center or go through Media Center Setup​
2. Install Media Center TV Pack 2008
a. Windows Media Center TV Pack 2008 (x86)​
b. Windows Media Center TV Pack 2008 (x64)​
3. Install the PlayReady PC Runtime
a. PlayReady PC Runtime v1.0 (x86)​
b. PlayReady PC Runtime v1.0 (x64)​
4. Install the following patches from the Download Center
a. KB951685 - The video playback application stops responding when you watch video or Live TV on a Windows Vista-based computer​
b. KB950754 - Noticeable problems occur in the video when you use the DirectSound renderer on Windows Vista​
5. Install any required or recommended Windows Updates
6. Launch Media Center and go through Media Center Setup
only the 32bit pack rtm as been leaked at the moment...
i don't know if that the best card, it just an example
Hauppauge WinTV Nova-T 500.
Hybrid/Analogue is dead.
And will the TV pack be released as a public update once its cleared through the RTM channels?
Just had a search around the internet. Seems MS may yet again screw over its customers by making this an OEM and new purchase only release. Apparently in over a year of testing, they havent even looked at testing an update proccess :(
I bought a new PC like, 4 days ago to be my Freeview/DVD/BluRay/Media beast! GRRR
I wont ever buy another compro card again. Had endless trouble with the software crashing constantly, as well as the poor interface of it all and not being able to get some of the main channels which the rest of the freeview receivers in my house could get!
