What upgrade from HD595??
21 Jan 2003
Had my HD595s for 4 years now and have seen tons of use, and while very good, looking to try something different.
Budget around £150 and maybe £75 for a headphone amp (recommendations?) or a dedicated soundcard. Only criteria for the headphones is they need to be open-backed and have detachable pads.
Was looking at the HD598s?
The Q701 are a different signature. If you want something colder, more detailed and spacious the Q701 are a shout. If you want something similar to the HD595 but with better resolution, mids, treble and balanced sound look into HD600(Used or sale)
The HD598 has good mids but I would probably look into something better in other areas.
I went for a pair of AKG 702's off Amazon for £159. Gonna look at an Asus STX soundcard next, thanks for replies.
