- 31 Oct 2005
- South-West
Hi there,
G/F has an Advent T9305 and just wondering what is the best CPU it can be upgraded to?
CPU-Z says it's a socket 775 with an MSI MS-7046 with a 915P/915G Chipset.
DDR RAM with a Prescott P4-HT @ 3ghz atm. I have a feeling that the best it will take is a P-D and not the Core2's but here's hoping!
Taken from the mobo manual I found online:
CPU
Supports Intel® Pentium 4 Prescott LGA775 processors in LGA775 package.
Supports up to Pentium 4 3XX, 5XX sequence processor or higher speed.
Supports Intel Hyper-Threading Technology.
Chipset
Intel® 915P chipset
- Supports FSB 533/800MHz.
- Supports DDR 400/333 memory interface.
Intel® ICH6 chipset
- Hi-Speed USB (USB2.0) controller, 480Mb/sec, up to 8 ports.
- 4 Serial ATA ports with transfer rate up to 150 Mbytes/sec.
- 1 channel Ultra ATA 100 bus Master IDE controller.
- PCI Master v2.3, I/O APIC.
- ACPI 2.0 Compliant.
Now in the manual it says it won't take more than a 5XX series but it has the following chip:
CPU Type Intel Pentium 4 630, 3000 MHz (15 x 200)
It's only the cpu that needs upgrading really as they don't game (X300
), it has 1GB RAM with WinXP so 600MB+ free at startup, 250GB HDD with 170GB+ free etc. It just doesn't repsond nicely with the P4 so a Core2 would be great.
If it can't take a Core2 what's the best it can take and would the upgrade be worth it?
Any more info can be given if needed.
Cheers very much guys & gals, Doug.
CPU
Chipset
Intel® 915P chipset
Intel® ICH6 chipset
), it has 1GB RAM with WinXP so 600MB+ free at startup, 250GB HDD with 170GB+ free etc. It just doesn't repsond nicely with the P4 so a Core2 would be great.If it can't take a Core2 what's the best it can take and would the upgrade be worth it?
