what virtualisiation software for desktop
9 Jan 2003
Cornwall
what does everyone use?
I've been trying out virtualbox (as it's free) and was just wondering if there are better free options out there for running on a vista x86 system for demonstrating different OSs in a VM (server2003/XP/vista/server2008 etc)
ideas?
after testing VirtualPC, Virtualbox and VMWare (spent about 3 days doing it) in work to see which would suit me best
i decided on Virtualbox, the other two seemed slower and heavier on system resources
VMware has the best networking features, but virtualbox does everything i need it to, so i'm using that
I have just started using Virtual Box at home it seems to do the job nicely. Vista x64 host x64 Virtual Box running XP Pro SP3, I don't think I have ever seen XP Pro run so fast:p
virtualbox > *. :)
i don't know what vmware were thinking when they released vmware server 2. it's so damned horrible to use. i can't recommend vmware anymore. (unless your host machine is xp then vmware server 1 is fine) :(
and ignore any fool who says use virtual pc. that's so bad i can't actually believe micrsoft made it. :p
MS didnt make it.
It was made by another company about 8 years ago. MS just bought it, braned it, and stuck it out there. They didnt even change anything.
Can virtualbox give the virtual machine more than one physical core? I have been messing around with linux on virtualbox from within windows, and much prefer it as a program to vmware server. However, vmware lets you give the vm two cores of the processor, but as far as i can work out, virtualbox does not have this option?
