What Wall Mount?
26 Feb 2004
Hampshire, England.
Hey guys,
While I’m waiting to settle on what 26” screen to go for, I thought that in the mean time I could sort out what wall mount to get?
I’m a bit restricted by my room layout….
…basically I won’t be able to have one of those ones that you lift up/slide down :(
A sideways sliding one would be okay I think - providing it can slide on from right to left (As per picture).
Can anyone give me any recommendations or advice to [email protected] ;)
Thanks,
SW.
Right, I've gone and ordered the 26" Sony KDL-26S2010 and I need to know more that ever now which wall mount to go for :D
I don't even know where to start? Can anyone give me anything to start googling with or links etc.
Ideally, I'd like it here at around the same time as the screen arrives :p
Thanks in advance!
SW.
Nearly every wall mount ive seen requires you to lift the tv onto the mount which your not able to do with yours. So it looks like it could be a tricky one.
Possibly use a arm mount but dont know exactly what space youve got in your room. Maybe worth looking over at avforums.
Thanks for the reply!
Don't these style of wall mounts allow you to slide your TV on from the sides?
I've seen those arm mount ones actually, maybe worth me looking into them too if the style above is unsuitable :rolleyes:
Cheers,
SW.
movingtables said:
sam you didnt get the samsung !! lol ..
hope you enjoy your sony.
when is it arriving ?
try and do a mini review.
:p
I saw the Sony in-store and fell in love with it!
It was only showing the news, but the picture and sound were amamzing :eek:
Probably will do a review though? I think it'll be here by Tuesday.
I just wanted to get a mount sorted in the meantime :rolleyes:
Cheers,
SW.
Here she is, mounted, in all her glory :D
Now I need to sort my room out! It's not normally this messy btw...
I went for this wall mount in the end, bought it from a well known auction site.
Fitted up a treat ;)
Hopefully get round to doing a review at the weekend?
SW.
