what water cooler
16 Dec 2018
hi guys newbee here I bought a gaming pc last yr for sim racing I want to install a water cooler so I can over clock my cpu I have a (copy and paste from the original listing)
Gigabyte Radeon RX VEGA 56 Gaming OC 8GB HBM2 PCI-Express Graphics Card
Intel 660P 512GB M.2-2280 PCI-e 3.0 x 4 NVMe QLC 3D NAND Solid State Drive (SSDPEKNW512G8X1)
Asus PCE-AC56 Dual-Band Wireless AC1300 PCI-E Adapter (90IG00K0-BM0000)
Lian-Li Lancool One Midi Tower - Black Window
Gigabyte Aorus RGB 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual/Quad Channel
AMD Ryzen 7 2700X @ 4.3GHz Boost
it has a stock prisum fan on atm
I am thinking about these coolers what would you guys recomend?
EVGA CLC 280 Liquid / Water CPU Cooler, RGB LED Cooling 400-HY-CL28-V1
Corsair Hydro H115i RGB Platinum Intel AMD Liquid CPU Cooler CW-9060038-WW
NZXT Kraken X62 - 280mm All-In-One Liquid CPU Cooler, Intel/AMD/AM4/TR4
appreciate any advice:)
To be honest they'll all perform very well. It'll be mostly down to your personal preference of looks or preferred brand.
The EVGA and NZXT are the same but different fans. The H115i platinum is a coolit unit rather than an asetek one in the other two. I'd go for the NZXT as the fans are better than the H115i at lower rpm
