So, I have got the hint that I dont want to blow up my system using the current £40 (and 650w!) PSU. It probably only provides 400w anyway! It is a cheap Atrix brand.
So, I'm looking into some corsair and cm stuff, but was wondering what wattage you recommend. I have tried the online calculators, but I would like to hear it from a human, so here we go:
CPU: AMD Phenom x4 9650 (stock clock)
GPU: Nvidia 9800GTX (stock clock)
HDD: 1 SATA @ 7200 RPM (will be getting a second similar one soon)
RAM: 2 sticks of 2Gb @800MHz
OpDrive: 1 DVD+/-RW
PCI: None
Fans: 1x 140mm LED, 1x 120mm standare, 1x80mm standard
USB: Razer Keyboard and mouse
Think thats about it. Your help is appreciated!
OpDrive: 1 DVD+/-RW
PCI: None
