Is there an easy way to know what width tyre will fit on what rim?
I want to run 195/45/16 or 205/45/16 on a 7J rim, the originals are 195/55/15.
I did have 17 inch wheels on the car, but felt that they were impacting on the handling, so swapped to a smaller rim. I didn't go for 15's as I will be fitting larger brakes which won't fit behind them.
There is more choice in 205 width, but they are more expensive, Eagle F1s are £65ish in 195 and decent tyres are knocking on for £100 in 205 width.
