Can anyone provide a definitive answer to this question? First the issue - when I first installed Vista a year ago now, the command or file for Vista Backup only ever worked once but never since, I always get an error message with text saying backup file missing or corrupted. Now it's not the end of the world as I use Acronis 10 which probably does a much better job.
The question - if a were to reinstall Vista which would wipe the HD then use Acronis recovery to reinstall the backup image prior to the Vista reinstall would the Vista backup fault still be there or would reinstalling Windows have cured it? Theory states it should have cured the problem but would not using Acronis to reinstall a backup of the old drive not overwrite the new install so the fault would still be there.
If anyone does know the answer thanks in advance
