Starting to prepare for uni now since It will take me ages to get everything I need before I go. I doubt my current PC will be up to the job anymore (it's 5 years old now) So I am planning to get a new rig before I go but im not sure what will be best for me.
I like the portability of laptops but I also like the performance of PCs.
If I get accepted I will be doing Computer Science and Cybernetics at Reading so I will need something that can handle a lot of programming and the capability of dual-booting Vista and Linux (So probably a large hard drive). I would also have liked something which I can upgrade myself and do my own Tech support on. It is for these reasons I was considering a PC
On the other hand it would be handy to be able to bring a Laptop to lessons and take notes on that. Would also be handy If I wanted to work in the library or somewhere other than my room as the campus is almost completely wireless enabled. I was also considering when I nead to move my stuff back home at the end of the year, it would be far easier to just put the laptop in it's bag and not have to worry about wires.
Which should I go for? PC or Laptop? Both?
Would my old PC maybe be up to the job if I got a laptop too?
Is there anythign else I should consider/look out for?
My current (ancient) spec
Cheers,
Mitchel
(P.S. I don't need a spec as I wont be buying anything for a while yet)
Cheers,
Mitchel
