What windscreen wiper from Halford?
12 Apr 2007
Need a new one today so will just buy from Halfords...
From memory they sell Bosch and some other (own) brand?
I remember not being hugely impressed with Bosch ones... Worth a punt on the other brand?
halfords can check with your reg number for exact ones
They sell Bosch or Halfords branded ones
if your only buying from halfords, get their own branded ones
amazon sell the bosch ones cheaper
I have always found the Bosch Aerotwin wipers to be great
But i have not tried the standard style of bosch wipers,
Then again i never found any make of the standard kind of wiper blade to be any good.
Just to be the odd one out I normally choose Valeo over Bosch after I had a set of Bosch ones go crappy on me over a very short period of time.
Same here - I had a set of Aerotwin that were brilliant compared to whatever was on the car when I got it (knackered things). But a year later they judder quite a bit.
IMO wipers shouldn't need replacing every single year, or I haven't had to anyway.
aerotwin style might be aerodynamic ... but when you compare the force distribution along the blade versus trad ones they over-pressure the middles producing uneven wear,
least ways, both of front ones I changed showed that; and the rear one with blade end closer to the pivot point wears at end because of higher G forces.
- maybe coating the screen is more economic.
