What wireless card to go with Linksys WRT54GL
17 Apr 2006
As the topic says... what wireless card would go best with the Linksys WRT54GL wireless router/switch?
[bit of a noob with wireless as only ever had wired networks before!]
Cheers!
USB, (mini-)PCI, PCMCIA, ExpressCard? For any particular OS?
Most cards will work fine - the GL does 802.11g and can be made to do Speedbooster. The latter requires a specific line of Linksys cards.
Just for XP. Noticed that most of the LinkSys cards are out of stock... will another make of card be OK or could I expect trouble?
Thinking of waiting for stock on: Linksys WMP54G Wireless-G PCI Adapter
As its cheap and seems to have good reviews... can anyone see any problems with this idea? :)
Speedbooster won't work (not that it's much advantage), but beyond that it'll work fine with any brand of card - so long as it's 802.11g.
