what wireless internet card can i use on 64 bit?
3 Jun 2009
as i now have windows 7, and its 64 bit... what wireless card can i get for my pc that will definatly work so i can connect to a wireless router?
really not sure wether to stick with 64 bit or drop 2gb ram and go back to 32bit as nothing seems to work.
I use a belkin F5D7050 usb device and its fine in Windows 7 and Vista x64 versions
Make sure you get a version 4 tho as version 2 dosent work with 64 bit
Edimax EW-7728In works with all 32bit & 64bit systems, including vista 32 & 64.
Also the BlueNEXT BN-WD54G usb wireless adaptor is another I can highly recommend to work with all windows OS
Found Windows7 to be great as it has most if not all my latest drivers built in, be sure to run an update as it will find the drivers.
