What would be better??
possibly... when I was researching the 5870 with a view to buying it this card was even getting bottlenecked by an overclocked i7. (Guru I think). However, this was only in a couple of tests.
Or... you could go AMD Phenom 955BE w/mboard and get another 4870 512mb to crossfire for possibly less than the 5870. The xfire would last you until you could afford a tope end card by which time they may have dropped in price anyway
He is correct there about even core i7 was bottlenecking but thats at very high res. I would personally get the 5870 and overclock the cpu a bit more. Also, if you aint bothered about dx11, 4890 in crossfire is faster than a single 5870 and a little bit cheaper.
It was def on Guru's website and the bottlenecking was happening at different kinds of res. In fact I think it was the lower res' that the bottlenecking. Either way it can happen even with the "mighty" i7.
I agree with the above option as well. Kind of. I think my option would be cheaper. My option, however, would only be better if you didn't care that much about dx11!!
