- 22 Mar 2009
- Cornwall
i currently have :
any thoughts?
which is ok, but was wondering, would i be better go for less ram but higher speed so i might be able to OC my cpu a bit more. looking at this :Key Features:
* PC type Desktop PCs
* Module specification 240Pin Unbuffered DIMM Non ECC
* Die layout 128*8
* Capacity 8GB Kit (2x4GB)
* Data transfer bandwidth 10,600MB/Sec (PC 10600)
* CL-value 9-9-9-24
* Working voltage 1.5V±0.075V
* PCB structure 6-layer PCB
* Extra features Aluminum heat-sink (According to the actual products)
* Warranty Lifetime warranty
Key Features:
* Suitable for Desktop PCs
* Module Type 240Pin Unbuffered DIMM Non ECC
* DRAM Density 256x8
* Capacity 4GB Kit (2x2GB)
* Data transfer
* bandwidth 14,928MB/Sec (PC3 14900)
* CL-value 9-11-9-27
* Working voltage 1.65V
* PCB 8-layer PCB
any thoughts?
