what would be bowling score be
12 May 2011
Southampton
Last night I was on my last bowl at 10pin bowling and I had 141 points. I got a spare and then on the bonus roll a strike so what would my score be as the scoreboard turned off before it showed my final score! What would my score have been?
I had a google and all the calculators need to know the number of pins knocked down for every roll.
Depends how many you scored on the ball before the ball you made a spare with.
Say it was 5.
5 + 10 (for the spare) = 15 + 141 = 156
20 for the strike = 176
If it was counted 141 before the ball that made the spare and then with the strike added on top - your total would have been 171.
So you had 141 and the screen shut off, then you bowled 3 balls - a 9, a spare and then a strike?
The score would have been 180.
If it the 9 was counted on the screen inclusive of the 141 before it shut off then you would have had 171. ^^
That is hard to summarise on a hung over Saturday morning. :(
I hope its clear enough.
