what would happen if
16 Sep 2005
What used to be a UK
I connected my spare sata hard drive to a system that already has an active operating system on it? The spare sata drive also has win xp on it from a previous pc with a different mobo which I really don't wish to use. I am only after transferring some old files so a reformat is out of the question, at least until I recieve the files I want. Thank you.
It will ask you which one you want to boot.
Actually it will say select either
'Windows XP or
Windows XP'
which isnt really much help!
'Windows XP or
Windows XP'
I had wondered about that it's just that I was under the impression there could be a conflict as the second (spare drive) was installed on a completely separate system, for example Asrock dual vsta, whilst the system I would be adding it to is using a gigabyte ds3p. Sorry if this sounds confusing. :)
it wouldn't conflict because your main hdd is pluged in port 1 right? port 1 is the bootup
Presumably I would then be able to format the second sata from the first one once I had copied over the files I needed?
