As long as the computer is off and the can of air is the right way up you should have no problems.
Yeah it isn't cheap.Compressed air is a massive rip off
I'll have to try that method.I have used both methods and as good fun as it is to use compressed air I found the brush and hoover method FAR more efficient and effective at cleaning and removing dust from inside a computer!!
Plus it's shed loads cheaper!!
I've been using compressed air for a number of years and have always used it the right way up, what would happen if you tried to use it upside down
p.s. I know, try it and see![]()
Oh right, thanksA freezing cold liquid![]()
