What would I need to spend?
6 Jun 2004
I have an AGP Mobo and have a 128mb ATi 9550 in there at the moment.
I only play Half Life 2 and it struggles at 1280x1024.
What card would do this without breaking a sweat, and make it look pretty?
I'm happy to go s/h, so if you think something older would be good then fine - I'll keep an eye out for one on a well known auction site ;)
Cheers,
James
P.S. Please don't suggest anything monsterously expensive, I'm just about to buy a house so am skint!
Cheers,
James
lol 1280x1024 on a 9550 :eek:
Anyway, both my 9800PRO & X700 can handle HL-2 at 1280x1024 with some decent FPS. Say CAN because the better the card the more details the game turns on. So, I reduce res to 1024x768 to enjoy the eye candy at even higher FPS :p
Also, helps if you give a budget :cool:
EDIT: Look out for 6600GT should be cheap & fly :D
Thanks mate.
Well, the budget is as little as possible really - I'd prefer to get something s/h, and could probably go up to £50 plus whatever i'd get for my 9550 (£3.25 probably lol)
Cheers,
James
You can get both Club 3D and Aopen Aeolus Geforce 6600GTs from a competitor site for about £75 inc. VAT, obviously I am not allowed to link that site here but they're out of stock here and you should be able to find them easily enough. :) My Chaintech 6600GT used to play Half Life 2 in pretty rox0r detail, very well-coded game. :cool:
