So I have just purchased Amazon Echo Dot and would like to voice control my devices in two rooms (living room and a bedroom)
The living room has the following:
- Steambox PC connected via HDMI to the telly,
- Sony Bravia TV,
- Virgin Media TV box (nothing fancy just the regular box),
- PS4 console,
- PS3 console,
- Google Chromecast.
Bedroom is equipped with only the TV (again Sony Bravia) + Google Chromecast and Amazon Fire stick.
I figured that Logitech Harmony is what I need but from what I have read the information is more confusing than actually helping me decide!
So what would I need in order to issue basic turn on or off commands from the remote or smartphone app to my devices?
Will the harmony hub be enough to accomplish my task or would I need the remote as well (don't mind using just the smartphone app or Alexa)?
Can 1 remote or hub control equipment in two separate rooms or do I need two sets?
Also, what is the difference between Harmony Hub and Harmony Ultimate Hub (apart from the £20 price difference)?
http://www.logitech.com/en-gb/harmony-remotes
Any input would be much appreciated to help and clear the confusion!
cheers.
- Sony Bravia TV,
- PS4 console,
- PS3 console,
cheers.
