OK so as per previous post I just wanted to check if this is worth doing before I go ahead and spend some hard cash. My current spec is i7 920, ATI 5850, 6GB RAM, X58A UD3R, Samsung F3.
Due to mother board issues I am going to scrap my current choice and replace it. I have around £400 to spend but not sure what route I should go.
Go for the i5 2500k, new motherboard and new RAM and keep with the current GFX card etc.
Or would I be best taking the £400, spending it on a mobo for my i7 and then look at upgrading my gfx card and getting a SSD drive? Perhaps look at a new case as well since the ATCS 840 is a little bit to big.
Im leaning towards the i5, with 8gb RAM and a new Mobo.
What would you suggest is the best route?
(PC is used mostly for gaming, with everything as close to max settings as possible)
Thanks!
PS - PSU is a Corsair 750 modular so not needing to change that.
Thanks!
