Hi all, a general question to you all out there on what I should try and upgrade first. My current system is in my sig and was built very recently as a stop gap solution until I get the finances sorted for some upgrades.
Basically my choice is the age old cpu or gpu upgrade. Now normally the gpu is the best choice but in my case it's not so clean cut as my cpu is only a dual core Pentium K (oc'd to 4.6GHz) and I'm running xfired 6950's. I suspect that the gpu's are already going to be a bit bottle necked by the pentium so my guess is that any further gpu power (probably a 290) won't really result in much more performance?
If I go for the cpu it'll probably be a 4790K which will remove any current bottleneck but I'm guessing it still wont be that much extra performance as the 6950's are getting on a bit now.
So if it was your system what you go for first?
Ross
Ross
