What XSPC Kit for 600T ??
17 Oct 2011
Antrim. N.Ireland
Hi,
Can someone help me by telling me what XSPC kit would fir in my new white 600T case. I dont want to mod it, just want it to fit. Do I need to buy an extra rad? Im very new to watercooling so please keep it simple speak :) Im not afraid of it either :) Oh and what fluid and colour would go with the 600T white and black case? Thanks,
Rasher
any xspc kit with a 240 radiator
have you considered this kit?
it will fit perfectly in the 600t
perhaps consider not using the fluid on the kit and check out the mayhems black coolant
looks fantastic in clear tubes
rjk
Thanks rjkoneill , Is the EK H3O a better kit than the xspc kits? I think its probably a bit more involved than the xspc kit. How difficult are they to fit and does EVERYTHING come with it or do I need to buy any extra's? I will check out the black fluid, cheers
You need to buy a GPU block of your going to be cooling the GPU.
Id personally get one of the OcUK kits over the EK ones as they come with better rads and pumps.
IIRC, you just need to buy some fittings but can't remember exactly. I'd say the EK and Xspc kits are pretty similar.
They're both easy to install. Just need to do some basic screwing and some cutting and that's pretty much it :)
The EK kit comes with a manual that takes you through everything.
And EK comes with the amazing boxes that makes your feel really special.
