what ya think of thisn spec?
Permabanned
14 Jun 2005
CA-037-CM Coolermaster Wave Master - Silver (No PSU) (CA-037-CM)
£74.95 £74.95
BU-012-OK AMD Athlon 64 3700 Retail / Asus A8N32-SLi Deluxe / 2GB Corsair XMS3500LL Dual Channel Kit - Bundle (BU-012-OK)
MY-107-CS Corsair 2GB DDR XMS3500LL TwinX (2x1GB) CAS2 (MY-107-CS) 1
CP-121-AM AMD Athlon 64 3700+ San Diego 90nm (Socket 939) - Retail (ADA3700BNBOX) (CP-121-AM) 1
MB-118-AS Asus A8N32-SLi Deluxe nForce4 SLi X16 (Socket 939) PCI-Express Motherboard (MB-118-AS) 1
£339.85 £339.85
HD-027-SA Samsung SpinPoint T HD300LD 300GB ATA-100 8MB Cache - OEM (HD-027-SA)
£60.50 £60.50
MO-016-OK OcUK Gamer Extreme 178GP 17" LCD Monitor - Black (MO-016-OK)
£93.95 £93.95
GX-115-SP Sapphire X1600 Pro 512MB DDR2 AVIVO TV-Out/DVI (PCI-Express) - Retail (GX-115-SP)
£76.95 £76.95
KB-046-LG Logitech S96 PS/2 Optical Wheel Mouse Black - OEM (KB-046-LG)
£5.50 £5.50
KB-011-LG Logitech Internet Pro Keyboard (Black) - OEM (KB-011-LG)
£8.95 £8.95
Dont get an SLi motherboard unless you intend to use 2 nvidia cards... not only that but ditch the 512 mb ddr2 x1600 pro... buy a 256mb Graphics chip that has gddr3 instead, preferably nvidia if you want to keep the SLi mobo
If you wait for OcUK to get the GDDR3 versions of the new 7300GT then that'll be your best bet, should cost about £60, and if you choose to SLi them later on, it'll be faster than a single 7900GT once they're overclocked!
i need to order tonite
here is my final spec
what ya think ?
£74.95 £74.95
£60.50 £60.50
£93.95 £93.95
£5.50 £5.50
BU-028-OK AMD Athlon 64 3700 Retail / Asus A8R32-MVP Deluxe / 2GB Corsair XMS 3200C25PT Dual Channel Kit - Bundle (BU-028-OK)
MY-079-CS Corsair 2GB DDR XMS3200C2PT TwinX (2x1GB) CAS2 (MY-079-CS) 1
MB-131-AS Asus A8R32-MVP Deluxe Crossfire (Socket 939) PCI-Express Motherboard (MB-131-AS) 1
£309.85 £309.85
GX-043-HT HIS Excalibur ATI Radeon X1800 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-043-HT)
£174.95 £174.95
CB-041-GE Akasa Rounded Ultra ATA133/100/66 IDE Cable (0.45m) - Blue (CB-041-GE)
£2.95 £5.90
SP-043-CL Creative Inspire 5.1 P5800 Speakers - OEM (SP-043-CL)
£34.95 £34.95
SC-040-CL Creative Sound Blaster Audigy SE 7.1 Sound Card - OEM (SC-040-CL)
£15.95 £15.95
CA-012-AK Akasa Ultra Quiet 400W Paxpower Active PFC ATX2.0 PSU - Black Nickel (CA-012-AK)
£33.95 £33.95
KB-066-LG Logitech Media Keyboard Elite - Retail (KB-066-LG)
£16.95 £16.95
Subtotal £827.40
VAT £144.80
Total £972.20
Mixed reviews on the WaveMaster especially regarding Temps :( Anyway...
  • AMD Athlon 64 3700+ San Diego 90nm (Socket 939) - Retail (CP-121-AM) £79.95
  • Asus A8R32-MVP Deluxe Crossfire (Socket 939) PCI-Express Motherboard (MB-131-AS) £99.95
  • GeIL 2GB (2x1GB) PC3200 Value Dual Channel Kit CAS3 (GE2GB3200BDC) (MY-046-GL) £114.95
  • Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO) £139.95
  • Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM (HD-018-SA) £43.50 - That capacity for that price is a bargain, in fact i'd pick up 2 instead of buying a bigger size HD
  • NEC ND3550 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-035-NE) £19.95 - cover it up below (Bezel)
  • Seasonic S12 430W Silent ATX2.0 Power Supply (CA-000-SS) £44.95 - way better PSU ;)
  • Logitech Media Keyboard Elite - Retail (KB-066-LG) £16.95
  • Logitech S96 PS/2 Optical Wheel Mouse Black - OEM (KB-046-LG) £5.50
  • Creative Inspire 5.1 P5800 Speakers - OEM (SP-043-CL) £34.95
  • Samsung SM-920N 19" LCD Monitor - Silver/Black (MO-043-SA) £147.95 - 19 INCHES! Thank me later
  • Lian-Li PC-7 PLUS Silver Aluminium Midi-Tower Case (No PSU) (CA-038-LL) £47.95
  • Lian Li C-01A Aluminium CD-ROM/DVD-ROM Bezel (Silver) (CA-008-LL) £7.95
  • Subtotal £804.45
  • VAT £140.78
  • Total £945.23
Oh, onboard sound (mobo) can match if not outperform that Creative card (unless you wanted it for a different purpose) :cool:
CP-126-IN Intel Core 2 DUO E6300 "LGA775 Conroe" 1.86GHz (1066FSB) - Retail (CP-126-IN)
£129.95 £129.95
MB-020-DF DFI Infinity 975X (Socket 775) PCI-Express DDR2 Motherboard (MB-020-DF)
£129.95 £129.95
MY-012-GS G.Skill 2GB DDR2 LA PC2-5300 (2x1GB) CAS4 Dual Channel Kit (F2-5400PHU2-2GBLA) (MY-012-GS)
£99.95 £99.95
GX-044-CO Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO)
£139.95 £139.95
HD-046-WD Western Digital Caviar SE16 250GB 2500KS SATA-II 16MB Cache - OEM (HD-046-WD)
£49.95 £49.95
CD-078-SA Samsung SH-S182D 18x18 DVD±RW ReWriter (Black) (CD-078-SA)
£21.95 £21.95
CA-054-LL Lian-Li PC-7 PLUS Black Aluminium Midi-Tower Case (No PSU) (CA-054-LL)
£48.95 £48.95
CA-005-HP Hiper HPU-4K580-MK Type R 580W Modular ATX2.2 PSU - Black UV (CA-005-HP)
£54.95 £54.95
MO-012-AC Acer AL1916WS 19" Widescreen LCD Monitor - Black/Silver (MO-012-AC)
£144.95 £144.95
KB-058-LG Logitech Cordless Optical Desktop Rechargeable Black/Silver - OEM (KB-058-LG)
£29.95 £29.95
£34.95 £34.95
Subtotal £885.45
VAT £154.96
Total £1,040.41
Conroe will be quicker if you wait for it. Bit more because Wireless keyboard and mouse plus i think you need a 580v PSU for an 1800 .. mentioned in sticky here
PREPARE YOUR SYSTEM
Its not uncommon these days to require a good quality PSU (Power Supply Unit) . To achieve maximum compatability it is recommended to have atleast a quality 350+ Watt PSU. http://forums.overclockers.co.uk/showthread.php?t=121317
My personal findings show that the Enermax 350w+, Antec TrueBlue 480w, Hiper Type R 580w all work without problems on anything less than an X1800XT . For an X1800XT or X1900XT(X) GPU i would recommend a minimum of 580w
Didn't check what http://www.extreme.outervision.com/psucalculator.jsp said tho
