What-ya think?
11 Jan 2005
Birmingham
ACER ET.L640C.002 Lcd 8ms 600:1 (1680x1050) Widescreen Multimedia Monitor
  • Display Size: 20.1 Wide (433.44 x 270.90 mm)
  • Pixel Pitch: 0.258mm
  • Resolution: 1680 x 1050
  • Design Color: Silver
  • Brightness (typ.): 300 cd/m2
  • Contrast Ratio (typ.): 600:1
  • Max. Refresh Rate: 75 Hz
  • Viewing Angle (typ.): 140?(H) 130?(V)
  • Response Time (typ.): 8ms
  • Input Signal: VGA (Analog D-sub)
  • Speaker: No
  • Power Adaptor (100V-240V): Internal
  • Power Consumption: 65W (max.)
  • Kensington Lock: Supported
  • VESA Wall Mounting: 100 x 100 mm
New to LCD's/TFT's and widescreens, so, how pants is this :D? Might be buying as its £245 new from a compet.
~Psy
Eurgh noticed it only has d-sub connection, is dvi oh so much better :x ?
A benq 202 is 50quid more? So, is 50quid worth it for dvi+analogue??
Nice screen. Shame it's VGA only :/ And yes for a screen of that size and resolution you really do need DVI to get the best out of it :(
Arse -.- Oh well, I'll keep on the hunt :)
Found this:
Philips 200W6CS20 20" TFT 1680x1050, dvi input, 275 :)
