I have limited Ocing skills, so just settle for leaving most settings @ auto & upping the FSB daily by 5MHz till it falls over.
The trouble is it keeps on going up & I think I’m loosing my nerve to go higher!
The vcore seems very high, I believe the mobo auto adjusts its upwards as the FSB rises.
Core Volts, set to auto in BIOS & showing
1.488 in CPU-Z but 1.52 in BIOS
Asus P5B
E6400
2 x 512 Balistix PC5300
8 x 415MHz = 3.32GHz
memory is 1:1 @ 5.6.6.18 (I don’t actually know what this means)
Currently @ 55C TAT & CoreTemp, believe it or not Asus probe2 shows the same!
Its running BOINC 24/7 both cores 100% load, so its very stable.
Have run it @ 3.28GHz on stock cooler for 4 weeks and the temps were up to 73C.
should I up the FSB again today, or call it a day?
Any suggestion will be appreciated
Asus P5B
E6400
