I have just started to dabble in overclocking and do not want to go past a sensible overclock.
The CPU is a AMD Athlon 64 X2 3800+ and the graphics card is a Sapphire X1950Pro.
I have overclocked both by 10% and now running at:
2.2Ghz on the processor and 573.75 / 1514 on the graphics card.
In terms of temperature I am looking at 30C on the CPU and 39C on the graphics card.
This is air cooling and I have a Zalman cooler (round one with the 120mm fan within the blades) on the CPU and stock cooling on the graphics.
Got 2Gb of Geil DDR2 running in dual channel not overclocked.
Would it be reasonable to overclock more and if so by how much or should I just stick with what I have got?
Cheers
Cheers
You don't really have to worry about breaking anything... Just don't do stupid things like setting the VCore to the max setting and **** and you'll be fine
