HI all,i,m coming up to upgrading my pc and having had it custom made 2 yrs ago i want to update it 1 last time,So i have been looking at this OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz Max / Asus Rampage II Extreme Intel X58 Motherboard / Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz DDR3 Bundle.
My questions are
1.will this fit in my thermaltake armor case
2.will i need any other things ie for cooling etc
At present i have a q6700
680i motherboard and a gtx 285 oc
i only use my pc for gaming mainly fps and web browsing etc
i have only been waiting as i want to put windows 7 in 64bit on pc when its out as at the moment i,m using windows vista 32 bit and upgrading now i wouldnt get the benifit of the 6gb of ram etc so want to do it all at the same time.I won,t be doing the upgrade myself as having to pay for a pc repair shop to do the work for me as i wouldnt have a clue what i,m doing and even tho its going to cost me £200 for them doing it i,m hoping it will all be fine after the trouble i have had with another pc shop buggering up my pc 3 times including oc my pc for me then it being all wrong bsod on me crashing then my graphics card blowing up which they denyed was there fault not had much luck finding a good place hope this 1 will be better
Many thanks
My questions are
Many thanks
