AS5 or Coolaboratory Liquid Pro?.
I have both and I'm using the Liquid pro just now.
The reason I'm asking is that I only applied the Liquid Pro after I got my DFI Ultra-D as a power surge killed my bios on my old MSI Neo 4 board. The DFI has now changed my airflow which consisted of my intake at the front going through the Freezer Pro and then out the exhausts on the back of my Thermaltake Kandalf case. So the Freezer fan was facing the front of my case and the passed the intakes air through and out the exhausts.
So now the freezer pro is facing straight in the air with the DFI board and has dirupted the good airflow I had previously. This is why I can't tell what is better. Also my overclocked X1900 sits directly underneath it and even though the card spits out the hot air out the back there is still some heat that comes off the back of the card which raises right into the heatsink of the Freezer Pro. So while the Freezer Pro is pushing the air through the heatsink the hot air is rising against it.
There is just no way to compare and I was hoping that someone here could sort me out with my awkward question.
