Whats Better ?
23 Dec 2004
Devon
Hi,
Currently using a Gigabyte DS4 rev 1.0 with a Q6600 GO.
A mate has offered me his Gigabyte GA-P35C-DS3R at a very low price.
How do the DS3R'S clock compared to the DS4 rev 1.0 ?
Many thanks.
I had a DS3R, very nice boards.. I got my E6750 to 3.2Ghz at everything stock, which seems normal on those mobos.
Mine died though, Went into a constant cycle of reboots before reaching POST.
Not sure what to do !
After looking on the net etc i think its worth changing.
How does the DS3R clock ??? with you guys ???
What kinda FSB can you get with the DS4?
Unless it's holding back your overclock, then it could be argued that the DS3R is actually a downgrade as the P965 chipset was pretty damn good.
My DS4 will not allow over 3.0 gig stable.
Have tried everything over the last 12 months. :mad:
So i reckon its time for a change
The rev 1.0's were never that great with quads. ~330mhz FSB was usually the limit. The later revs were a little better, but the P35 board will be a lot better for overclocking.
