What's crashing?
16 Oct 2007
UK
My system crashes fairly regularly. Can anyone gain an idea of the cause from the below? THanks!
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Mon 8/31/2015 4:49:15 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\083115-39890-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1729A0)
Bugcheck code: 0xA (0xFFFFF6D90078CE08, 0x2, 0x0, 0xFFFFF80093CA5F64)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntfs.sys (NTFS+0xD0D48)
file path: C:\Windows\system32\drivers\ntfs.sys
description: NT File System Driver
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Mon 8/31/2015 2:59:02 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\083115-37812-01.dmp
This was probably caused by the following module: netio.sys (NETIO+0x10FBC)
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF801BA7B0FBC, 0x0, 0xFFFFFFFFFFFFFFFF)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\drivers\netio.sys
description: Network I/O Subsystem
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
On Mon 8/31/2015 2:55:26 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\083115-39937-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF8036DB88117, 0xFFFFD001CB6D9DA0, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
On Mon 7/20/2015 12:12:54 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\072015-37937-01.dmp
Bugcheck code: 0x1A (0x41793, 0xFFFFF6807C9F5FF0, 0x1FF, 0x1FE)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Mon 7/20/2015 10:56:44 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\072015-38437-01.dmp
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF801085C0FBC, 0x0, 0xFFFFFFFFFFFFFFFF)
On Tue 7/14/2015 1:25:38 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\071415-38343-01.dmp
Bugcheck code: 0x12B (0xFFFFFFFFC00002C4, 0x73E, 0x968BA30000, 0xFFFFD0017F37C000)
Error: FAULTY_HARDWARE_CORRUPTED_PAGE
Bug check description: This bug check indicates that a single-bit error was found in this page. This is a hardware memory error.
This is likely to be caused by a hardware problem problem. This error suggests a case of memory corruption because of a hardware problem. It is suggested you do a test on your RAM modules (memory test).
On Sat 7/11/2015 11:46:20 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\071115-38171-01.dmp
Bugcheck code: 0x50 (0xFFFFF6FB40000000, 0x0, 0x0, 0x6)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
On Mon 7/6/2015 12:35:56 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\070615-11375-01.dmp
Bugcheck code: 0x1A (0x41792, 0xFFFFF680002CBA00, 0x200000000000000, 0x0)
On Mon 7/6/2015 12:31:33 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\070615-11750-01.dmp
Bugcheck code: 0x1A (0x41793, 0xFFFFF6800002FF20, 0x2, 0x1)
CPU-Z TXT Report
Binaries
CPU-Z version 1.73.0.x64
Processors
Number of processors 1
Number of threads 8
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
-- Core 2
-- Thread 0 4
-- Thread 1 5
-- Core 3
-- Thread 0 6
-- Thread 1 7
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 2.732 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 8 (max 16)
Name Intel Core i7 930
Codename Bloomfield
Specification Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz
Package (platform ID) Socket 1366 LGA (0x1)
CPUID 6.A.5
Extended CPUID 6.1A
Core Stepping D0
Technology 45 nm
TDP Limit 130.0 Watts
Core Speed 2931.1 MHz
Multiplier x Bus Speed 22.0 x 133.2 MHz
Rated Bus speed 2398.2 MHz
Stock frequency 2800 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 4-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max turbo frequency 3066 MHz
Max non-turbo ratio 21x
Max turbo ratio 23x
Max efficiency ratio 12x
TDC Limit 110 Amps
Max bus number 63
Attached device PCI device at bus 63, device 2, function 0
Attached device PCI device at bus 63, device 3, function 4
Temperature 0 38°C (100°F) [0x3E] (Core #0)
Power 0 28.36 W (Package)
Monitoring
Mainboard Model X58A-UD3R (0x00000251 - 0x02C7AA00)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8720
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8720
LPCIO Revision ID 0x8
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 20 08 00 00 E0 FF 32 40 80 00 00 81 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor ITE IT87
Voltage 0 1.14 Volts [0x47] (CPU VCORE)
Voltage 1 1.65 Volts [0x67] (DDR)
Voltage 2 3.38 Volts [0xD3] (+3.3V)
Voltage 3 5.03 Volts [0xBB] (+5V)
Voltage 5 12.54 Volts [0xC4] (+12V)
Voltage 8 3.06 Volts [0xBF] (VBAT)
Temperature 0 36°C (96°F) [0x24] (Mainboard)
Temperature 1 34°C (93°F) [0x22] (CPU)
Temperature 2 41°C (105°F) [0x29] (Northbridge)
Fan 0 1366 RPM [0x1EE] (CPU)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 13 00 00 00 FF FF 00 37 FF 87 58 0F D7 EF FF FF
10 FF FF FF 76 D7 81 80 81 01 FF FF FF FF FF FF FF
20 3B 67 D3 BB 19 C4 09 87 BF 24 22 29 80 EA B2 B2
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 3C 80 3C 80 5F 74 2D 40 9C 00 FF FF FF FF
50 FF 2A 7F 7F 7F 50 FB FB 90 FB 04 12 60 00 00 00
60 00 14 41 23 90 03 00 FF 00 14 41 23 90 03 00 FF
70 00 14 41 23 90 03 00 FF FF FF FF FF FF FF FF FF
80 FF FF 00 00 FF FF 00 00 00 00 00 00 00 00 02 00
90 FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor Gigabyte DES
Voltage 0 0.94 Volts [0x3B] (CPU)
Hardware monitor NVIDIA NVAPI
Voltage 0 0.91 Volts [0x391] (VIN0)
Temperature 0 45°C (113°F) [0x2D] (TMPIN0)
Fan 0 1470 RPM [0x5BE] (FANIN0)
Fan PWM 0 40 pc [0x28] (FANPWMIN0)
Clock Speed 0 405.00 MHz [0x195] (Graphics)
Clock Speed 1 324.00 MHz [0x195] (Memory)
Clock Speed 2 810.00 MHz [0x195] (Processor)
DMI
DMI BIOS
vendor Award Software International Inc.
version F1
date 12/28/2009
ROM size 2048 KB
DMI System Information
manufacturer Gigabyte Technology Co. Ltd.
product X58A-UD3R
version unknown
serial unknown
UUID {00000000-0000-0000-0000-6CF049575897}
SKU unknown
family unknown
DMI Baseboard
vendor Gigabyte Technology Co. Ltd.
model X58A-UD3R
revision unknown
serial unknown
DMI System Enclosure
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer Intel
model Intel(R) Core(TM) i7 CPU
clock speed 2933.0 MHz
FSB speed 133.0 MHz
multiplier 22.0x
DMI Memory Controller
correction 8-bit parity
Max module size 1024 MBytes
DMI Memory Module
designation A0
size 2048 MBytes (single bank)
DMI Memory Module
designation A1
DMI Memory Module
designation A2
DMI Memory Module
designation A3
DMI Memory Module
designation A4
DMI Memory Module
designation A5
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
designation No Detected (external)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB (internal)
port type USB
connector Access Bus (USB)
DMI Port Connector
port type USB
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 49152 MBytes
max# of devices 6
DMI Memory Device
designation A0
format DIMM
type unknown
total width 2304 bits
data width 2252 bits
size 2048 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
DMI Memory Device
designation A2
format DIMM
type unknown
size 2048 MBytes
DMI Memory Device
designation A3
format DIMM
type unknown
DMI Memory Device
designation A4
format DIMM
type unknown
size 2048 MBytes
DMI Memory Device
designation A5
format DIMM
type unknown
Storage
Drive 0
Device Path \\?\scsi#disk&ven_&prod_ocz-arc100#4&37df755d&0&010000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name OCZ-ARC100
Capacity 223.6 GB
SMART Support Yes
Drive 1
Device Path \\?\scsi#disk&ven_samsung&prod_ssd_830_series#4&37df755d&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name SAMSUNG SSD 830 Series
Capacity 119.2 GB
SMART Support Yes
USB Devices
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x046D, product=0xC534
USB Device ASUS USB-N53 802.11a/b/g/n Network Adapter, class=0x00, subclass=0x00, vendor=0x0B05, product=0x179D
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce GTX 570
Board Manufacturer EVGA Corp.
Revision A1
Codename GF110
Technology 40 nm
Memory size 1280 MB
Memory type GDDR5
PCI device bus 3 (0x3), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x3842)
Model ID 0x1081 (0x1572)
Performance Level Default
Core clock 50.5 MHz
Shader clock 101.0 MHz
Memory clock 135.0 MHz
Performance Level 2D Desktop
Core clock 405.0 MHz
Shader clock 810.0 MHz
Memory clock 324.0 MHz
Performance Level 3D Applications
Core clock 797.0 MHz
Shader clock 1594.0 MHz
Memory clock 1950.0 MHz
Win32_VideoController AdapterRAM = 0x50000000 (1342177280)
Win32_VideoController DriverVersion = 10.18.13.5354
Win32_VideoController DriverDate = 07/13/2015
Monitor 0
Model HZ281H ()
ID HSD6735
Serial 146LM3AY00274
Manufacturing Date Week 46, Year 2011
Size 27.4 inches
Max Resolution 1920 x 1200 @ 59 Hz
Horizontal Freq. Range 30-85 kHz
Vertical Freq. Range 50-75 Hz
Max Pixel Clock 170 MHz
Gamma Factor 2.2
Software
Windows Version Microsoft Windows 10 (10.0) Professional 64-bit (Build 10130)
DirectX Version 12.0
Register Spaces
Register space PCI
Register space PCI #2
Register space PCI Express, base address = 0x0F4000000
Register space SMBus, base address = 0x0500
Register space I2C
Register space I2C
Register space LPC, base address = 0x02E
Should I leave it to run some more?
Should I leave it to run some more?[/QUOTE]
let it finish testing about 8hr's
I take it your PC is over clocked? if it is then remove all over clocks and retest and use the pc for a week like that, to see if the crash's continue
Thanks buddy. I think I must have turned on XMP in the bios once due to a BSOD. I'll disable and try some more!
your fine aslong as you increase the qpi/vtt voltage (memory controller) or dram vtt on asus boards
I ran ram at 1800mhz on x58 sweet as a nut
manually set the vtt to 1.32v-1.35v
irq not less or equal is usually ram or memory controller voltage related
