there may have been a thread on this already - i get the impression that this is the sort of thing Beansprout and Augmented are all over!
i use IE at work, and we have flash forms which are created from ColdFusion...why is it that these forms are embedded but still autonomous objects...you actually have to select the object, then place your cursor in the field you want to fill out.
i may well be talking gibberish (it's still early) but hopefully someone can decipher something of this and give me a link/explanation as to why this has happened? it's bloody annoying!!
i use IE at work, and we have flash forms which are created from ColdFusion...why is it that these forms are embedded but still autonomous objects...you actually have to select the object, then place your cursor in the field you want to fill out.i may well be talking gibberish (it's still early) but hopefully someone can decipher something of this and give me a link/explanation as to why this has happened? it's bloody annoying!!
