whats going on with my line ?
30 Aug 2006
here is stats from router BT HH v3
seems to be a lot off errors and faults ?
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 1 days, 07:02:11
Downstream: 7.938 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Fast
Noise margin (Down/Up): 5.0 dB / 27.0 dB
Line attenuation (Down/Up): 38.3 dB / 21.5 dB
Output power (Down/Up): 19.9 dBm / 11.8 dBm
FEC Events (Down/Up): 0 / 33
CRC Events (Down/Up): 38940 / 97
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 119874 / 137
Error Seconds (Local/Remote): 9570 / 152
Quite a few errors. Just compared it with mine. I have 3 days uptime and no CRC errors so far on download (which has been hammered the last day or so) and 3 on upstream.
It seems that you are having about 1000 failed packets every hour. So a packet is being sent and is being corrupted enough that it can't be reassembled at the other end. This could be because your latency is Fast which has less error correction than interleaved.
Have you monitored the stats with Routerstats to watch for trends?
Mine used to go funny at around 10-11am and whenever phone was used. Had to get BT out who couldn't find a fault but replaced a couple of things anyway which cured the issue somehow.
Does the router ever lose signal and have to reconnect?
