What's going on with my Safari?
19 Oct 2005
Kernow
Hi there,
Just came to my MBP and now webkit or safari won't open, just bounces in the dock repeatedly and doesnt open at all, just crashes.
Tried app zapping webkit, then app zapping safari, reinstalling safari then using onyx to run scripts and clean up anything and then reinstalled safari again but to no avail! Still doesnt work.
What else should i do? Dunno why it's not working. Infuriating...
Josh
Does it work if you login to OS X with a different account?
Did you have any plugins enabled like Saft or SafariStand? Could be something like that causing problems if they have b0rked.
You could also check the console to see if there are any useful messages in there about it.
Right, i sorted it yesterday.
Had to uninstall everything with app zapper, then download the combo update and then do an intensive clean with everything in onyx (don't know which one was needed) then ran the 10.5.4 combo update and restarted.
Installed Webkit, fixed!
