Whats going on?
I think 5770 is now supported by OpenCL. However I think I read somewhere that some functions might be unsupported, e.g. double precision.
You'll need to read the documents of OpenCL/Stream SDK from AMD.
You mean you want GPU-Z to show that your 5770 supports "OpenCL"? If you install the latest version of Stream SDK and reboot, that should work. However if you never use OpenCL why bother?
