whats interleaved mean?
Interleaving is set to Auto by Bt wholesale. If your line keeps dropping during testing they will switch interleaving on as this will make your line more stable, but has a slight impact on gaming with pings being a bit higher than normal. However downloads should be faster and web browsing.
I dont use my computer to play games no more so it is just as fast as normal for web browsing and downloading then I take it?
The maximum sync rate is reduced a bit but other than that I don't think there's any real difference at all. I had interleaving enabled for a brief period of time on my line and didn't notice any difference in speed.
on my modem it does say I get lots of errors and 10mins worth of disconnection :o
